Yapı Kredi Teknoloji
TR
Posted: 4 weeks ago
Last activity: 3 weeks 3 days ago
Last activity: 30 Apr 2024 7:01 EDT
PEGA Customer Decision Hub Portal execute error html problem
2024-04-26 00:06:22,054 [ttp-nio-8200-exec-20] [TABTHREAD4] [ ] [ CRM:01.01.05] (et_Aggregates_Dimension.Action) ERROR ovrcmpgntst| Proprietary information hidden U098741 - Failed to Find property [pyFulfilled]. 2024-04-26 00:06:22,054 [ttp-nio-8200-exec-20] [TABTHREAD4] [ ] [ CRM:01.01.05] (et_Aggregates_Dimension.Action) ERROR ovrcmpgntst| Proprietary information hidden U098741 - Failed to Find property [pyISFactID]. 2024-04-26 00:06:22,055 [ttp-nio-8200-exec-20] [TABTHREAD4] [ ] [ CRM:01.01.05] (et_Aggregates_Dimension.Action) ERROR ovrcmpgntst| Proprietary information hidden U098741 - Failed to Find property [pyRevenue]. 2024-04-26 00:06:22,057 [ttp-nio-8200-exec-20] [TABTHREAD4] [ ] [ CRM:01.01.05] (et_Aggregates_Dimension.Action) ERROR ovrcmpgntst| Proprietary information hidden U098741 - Failed to Find property [pyResponse]. 2024-04-26 00:10:39,984 [ion.Default-Pulse:34] [ STANDARD] [ ] [ ] (ation.AggregatesPulseOperation) ERROR - Error while executing maintenance. Will try again on next pulse com.pega.pegarules.pub.generator.RuleNotFoundException: Failed to find a 'RULE-DECISION-DATASET' with the name 'SENTOFFERSPROSPECT' that applies to 'CRM-SR'. There were 1 rules with this name in the rulebase, but none matched this request.
Show More
2024-04-26 00:06:22,054 [ttp-nio-8200-exec-20] [TABTHREAD4] [ ] [ CRM:01.01.05] (et_Aggregates_Dimension.Action) ERROR ovrcmpgntst| Proprietary information hidden U098741 - Failed to Find property [pyFulfilled]. 2024-04-26 00:06:22,054 [ttp-nio-8200-exec-20] [TABTHREAD4] [ ] [ CRM:01.01.05] (et_Aggregates_Dimension.Action) ERROR ovrcmpgntst| Proprietary information hidden U098741 - Failed to Find property [pyISFactID]. 2024-04-26 00:06:22,055 [ttp-nio-8200-exec-20] [TABTHREAD4] [ ] [ CRM:01.01.05] (et_Aggregates_Dimension.Action) ERROR ovrcmpgntst| Proprietary information hidden U098741 - Failed to Find property [pyRevenue]. 2024-04-26 00:06:22,057 [ttp-nio-8200-exec-20] [TABTHREAD4] [ ] [ CRM:01.01.05] (et_Aggregates_Dimension.Action) ERROR ovrcmpgntst| Proprietary information hidden U098741 - Failed to Find property [pyResponse]. 2024-04-26 00:10:39,984 [ion.Default-Pulse:34] [ STANDARD] [ ] [ ] (ation.AggregatesPulseOperation) ERROR - Error while executing maintenance. Will try again on next pulse com.pega.pegarules.pub.generator.RuleNotFoundException: Failed to find a 'RULE-DECISION-DATASET' with the name 'SENTOFFERSPROSPECT' that applies to 'CRM-SR'. There were 1 rules with this name in the rulebase, but none matched this request. The 1 rules named 'SENTOFFERSPROSPECT' defined in the rulebase are: 1 related to applies-to class 'CRM-SR', but were defined in rulesets which are not in your rulesetlist: 'CRM-Rules:01-05-45'. Current RulesetList: CRM-Artifacts:01-01, CRM-Rules:01-01, **Normally We use CRM-Rules 01-06 CRM-Propositions:01-01, CRM:01-01, CRMInt:01-01, Harmony:01-01, YKB:01-01, YKBInt:01-01,
When loading customer decision hub, the html opens in a corrupted manner. When I look at the logs, I see the error message above.There is no problem in the dev environment. I don't think the codes I put into the UAT environment are corrupted. I couldn't understand the reason for the error. Can you help me?
Show Less
