Zurich Financial Services AG
Last activity: 14 Aug 2024 8:34 EDT
Character Limit for New Rest Integration and Class Name
Dear Pega,
Please increase the character limit for the class name for new REST integration and the character limit for the class name.
Using the refactor functionality to rename the classes and manually having to run the refactor for each individual child class takes a considerable amount of time.
What normally takes about 10 minutes, turns into a couple our venture and make me want avoid using the the new REST integration function.
Reply
Updated: 14 May 2024 4:55 EDT
@MarijeSchillern Thanks for the reply. The issues wasn't with a new application; it was an existing application. I've decided against using the wizard due to the clean up involved and found it a lot easier and less time consuming to manually build the response and requests.
Updated: 9 Apr 2024 1:08 EDT
Maantic Inc
You have to raise a ticket with Pega in you MSP portal https://msp.pega.com. Pega GCS will connect with you with your requirements. If they feel that a patch is required, they'll raise a feedback request and provide you with a FDBK ticket ID. That ticket is tracked in Pega's internal agile studio which is not accessible to clients. They pickup these requests based on importance and if its approved by the product team, its implemented and released in the upcoming releases. Your Pega Account Executive should be able to help you with the process. You can get more info on how they're tracked here:
https://support.pega.com/support-doc/what-expect-after-support-ticket-resolution
@SohamM95 Thanks, I initially found the wizard helpful, but after using it a few times the clean up task was way to cumbersome. It was much easier and quicker to build by scratch. Hopefully Pega continues to expand on their wizards and allow a little more granular control.
Maantic Technologies Pvt Ltd
Hi @xJubeix
Change the precondition of step #1 in activity pyGenerationCheck of class Pega-DataModel-DataSources-REST based on your requirements in case you want to increase the length of the class.
Hope it helps.
Megha
@Megha007 I am hesitant to make modifications likes, in the past things would come back to haunt us if we opened a SR with Pega. =\
@xJubeix FDBK-65555 (Restricting the Class name size while creating a new application) already exists for consideration for future products.
Please can you click Accept solution against the reply which unblocked you?
@VenkatRaman That is what I was doing, but the Wizard was creating names that were too long for some classes. So I had to manually create the classes and delete the classes that were not refactored. I ended up spending more time correcting the wizard mess than it takes manually creating everything.
StateFarm
@xJubeix I agree. It depends on the data mapping or how big the Rest service is. Class refactor is a big time consuming task if there are so many rules in the application/DataBase.
