Upgrade script stuck upgrading from 8.6 to 23
I've just kicked off an upgrade of a cloned DEV environment from 8.6 to 23 but its been running now for almost an hour and seems to be stuck at the below point and not moved.
generate_upgrade_ddl:
Check zOS Upgrade: [echo] ***setting resume checkpoint*** [propertyfile] Updating property file: /common/PegaUpgrade/pega23/117667_Pega_23.1.1/scripts/resume.properties
Schema Upgrade:
Schema Upgrade Inner:
RunSQLLoader:
Should I be concerned its not doing anything or do I simply need to wait some more?
I should point out that this https://support.pega.com/support-doc/pega-platform-%E2%80%9923-installation-and-updates-stall-oracle-old-jdbc-driver-sdr-a161 doesn't apply as I'm using ojdbc11.jar on Oracle 19c.
Thanks Craig
