Authentication between Pega and external KAFKA in AKS deployment
We would like to know if our Pega Platform deployment in AKS can go for SASL using JAAS mechanism for authenticating to external Kafka service (Azure HDInsight) for different deployment scenarios
Here are the different AKS-HDInsight deployment topologies that currently exists in our Organization
- 1:1 AKS: HDInsight---->Individual AKS Cluster connecting to individual HdInsight service deployment
- Shared HDInsight----->Separate AKS Clusters hosting different apps and connecting to a single HDInsight
- Shared AKS cluster and shared HInsight ----->A single AKS cluster hosting multiple apps and sharing same HDInsight
To rephrase the question again , will Pega support SASL using JAAS mechanism for authentication for above scenarios ?
@SubhadaM
please see the answer provided in the Related Content flagged post Azure Event Hub for External Kafka
All the documentation can be found on docs.pega.com
Pega Platform supports SASL using JAAS mechanism for authentication to an external Kafka service in all the mentioned deployment scenarios.
Kafka externalization using Azure HDinsight for Pega
Replace External Kafka with Azure event hubs
External Kafka in your deployment > Connection authentication between Pega and your Kafka service
Authentication
