Could not get access token when using JWT Token Profile in Authentication profile- OAuth 2.0 authentication issue.
I am having a bit of an issue on how to use JWT profile as authentication schema within Authentication Profile.
We have created the Authentication Profile with JWT profile as authentication schema and when we run the REST connector with authentication profile, Its giving below error.
Access token endpoint invocation failed : {ErrorMessage=Response status : 400 Bad Request, statuscode=400}
* Attached Debug Details
Plus, if we used the same data (which is pass from pega side) in postman, its working fine and it's returning the token.
Nuwan
***Edited by Moderator Marissa to add Support Case details***
***Edited by Moderator Marije to add Enhancement (BUG-861639 ) tag***
@MarijeSchillern INC-B948 was created and provided enhancement in 23.1.2 version.
