Tata Consultancy Services
Last activity: 12 Dec 2023 7:05 EST
Modal from navigation rule not showing multiselect option
I am using Pega 8.7. When i am invoking a modal from a navigation rule, I am not able to see the multiselect field in the modal section even when I use template based section. The modal template used is OOTB pzModalTemplate.
Can someone help if some other config changes need to be done.
