Login URL with "_"
Please provide any explanations, materials, pages, etc. regarding [Login URL with "_"].
Current behavior: ① Login URL: xxxx/prweb, After logging in, the URL will be: xxxx/prweb/app/app name_/... (※ _ there is) ② Login URL: xxxx/prweb/app/app name/..., After logging in, the URL will be: xxxx/prweb/app/app name/... (※ _ there is not)
scenario: WorkLink is in your email. If you open the email WorkLink while logged in or not, the behavior will be different. In the case of ①, Worklink URL does not require re-login (ID/PWD input screen) regardless of whether there is a "_" or not. In the case of ②, If the worklink URL has "_", you do not need to log in again. If the worklink URL does not have "_", you will need to log in again. In addition, the login URL and WorkLink URL are If they are different (with or without “_”), the pzRequestorID is also different (same OperatorID)
Hi @wangd1: Please check this.
Thanks.
