How to unzip file which contains password protected file.
Below code works fine to unzip the zipped file (.zip), not password protected one.
ParameterPage MyParam = tools.getParameterPage();
ClipboardPage WorkPage = tools.getPrimaryPage();
ClipboardProperty StreamList = WorkPage.getProperty("pyModeList");
ClipboardProperty NamesList = WorkPage.getProperty("pyNames");
String TemplateName = MyParam.getString("TemplateName");
java.util.zip.ZipEntry entry = null;
try {
java.util.zip.ZipInputStream zipStream = new java.util.zip.ZipInputStream(new java.io.ByteArrayInputStream(Base64Util.decodeToByteArray(tools.findPage("AttachmentPage").getString("pyAttachStream"))));
ArrayList<String> OutputList = new ArrayList<String>();
ArrayList<String> NameList = new ArrayList<String>();
try {
while((entry=zipStream.getNextEntry())!=null)
String entryName= entry.getName();
if (entryName != null)
NameList.add(entryName);
Boolean IsDirectory = false;
if (entryName.endsWith(java.io.File.separator))
IsDirectory = true;
int bytesRead = -1 ;
java.io.ByteArrayOutputStream outStream = new java.io.ByteArrayOutputStream();
int len= (int) entry.getSize();
byte[] tempBuffer = new byte[8192];
while((bytesRead = zipStream.read(tempBuffer))!= -1)
outStream.write(tempBuffer,0,bytesRead);
if (outStream!=null)
String EncodedOut = new com.pega.pegarules.pub.util.Base64Util().encodeToString( outStream.toByteArray());
OutputList.add(EncodedOut);
if(zipStream!=null)
zipStream.closeEntry();
zipStream.close();
for(int i=0; i<OutputList.size();i++)
StreamList.add(OutputList.get(i));
NamesList.add(NameList.get(i));
catch (Exception ex)
{oLog.infoForced("failed " + ex.getMessage());}
