Is it possible to edit a key field on the records tab of a data type?
I needed to edit records udsing the "Record" tab of the data type (in either Dev or App studio), however, one of the fields I need to edit is defined as "key, read only". Thus the options are to delete the record and recreate it or to export the entire table, edit in Excel and import it back. Is there a way to change the field to editable within the data type? On the data model tab, settings are greyed out for key fields.
