![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2023-03/c0331455-a1ca-4bd1-88e5-3224532cd97b.png?h=70045d59&itok=r_nbdpN2)
Last activity: 6 Mar 2024 8:25 EST
End-to-end Pega Customer Decision Hub Implementation
The End-to-End Pega Customer Decision Hub Implementation mission presents a practical learning opportunity to build a Customer Decision Hub application from the ground up.
This mission focuses on testing your understanding of the fundamental concepts of Pega Customer Decision Hub™. The content provides you with hands-on experience to implement and manage a complete 1:1 Customer Experience implementation project.
In each challenge of the mission, you have the opportunity to encounter and overcome adversities that typically arise in a real-life project. The design of the use cases drives you to apply your knowledge, solidify your understanding of the concepts and build a strong foundation for future implementations.
Before you take this mission, ensure that you complete the recommended missions in the Pega Customer Decision Hub learning path.
For assistance, post your questions here.
Happy learning!
Reply
Raghukiran Shankhawaram Ali Sabry Ashroff Mete Kahyagil -
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689976000/cef8d0d6-5464-493d-8032-7823a68032fa.jpg?itok=VVrxjtbW)
JP Morgan
@kahym its not accessible
Updated: 21 Mar 2023 12:48 EDT
Standard Chartered Bank
@kahym I tried to access the Dev and BOE Links but it shows access is denied Can you please help in getting access to this links
These are the links
https://academy.pega.com/challenge/development-environment/v1
https://academy.pega.com/challenge/business-operations-environment/v1
@VaibhavJ6401 thank you for bringing this to our attention, and sorry for the inconvenience. You should now be able to access the URLs.
Areteans
@Mete Kahyagil- I'm able to access the links but most of the user credentials are not working for creating an application once you login? Could you please suggest?
Updated: 21 Jul 2023 8:08 EDT
@SaurabhK6708 Hi, Were you able to follow the following steps?
https://academy.pega.com/challenge/exercise-setup-development-environment/v1/
Have you made sure that you Enabled the operators, when importing the provided product file?
@SaurabhK6708 Hi Saurabh - apologies. I did not see the screenshot you have attached. 1- You have to create a SystemArchitect operator as defined in the requirements. (this operator is missing in your environment at the moment.)
2- After you create the SystemArchitect you need to configure the access group and run the wizard with the correct access group.
You can follow the steps in the following challenge to configure the operator. https://academy.pega.com/challenge/running-pega-customer-decision-hub-setup-wizard/v2
Hope this helps! Feel free to reach out to me if you have further queries!
Mete
Northbridge
Hi @Mete Kahyagil ,
I have a question regarding this mission . I have already posted and here is the url: https://support.pega.com/question/question-regarding-end-end-pega-customer-decision-hub-implementation-mission .
Could you please check?
Updated: 21 Jul 2023 8:07 EDT
@SamaptiP9074 - I have responded to your post. Please feel free to reach out if you have any further queries.
Cognizant
CN
The environments are access denied in the latest version of the course (Pega CDH '23)
These are the links
https://academy.pega.com/challenge/development-environment/v2
https://academy.pega.com/challenge/business-operations-environment/v2
Could you please check? thanks.
Updated: 10 Oct 2023 10:48 EDT
Accenture
SG
Not getting the CDHData Repository in the list while creating a new CDH application on the practice environment. Attached the screenshot
@MythilyN Hi,
I have not seen a mention of CDHData in the challenge, would you mind letting me know which directions are you following? Maybe there is an incorrect mention that I have to fix.
In the following challenge, it states that you should use filerepo, hope this answers the question.
https://academy.pega.com/challenge/use-case-running-pega-customer-decision-hub-setup-wizard/v2
GM Onstar
https://academy.pega.com/challenge/use-case-testing-engagement-policies/v1/in/52526
the Customer Profile Viewer - Properties for Subscription does not reflect what is there in the context dictionary - can someone help
Hi Sree,
Please feel free to directly reach out to me, and we can see what you are facing.
