Zensar Technologies Ltd
Last activity: 6 Mar 2023 6:55 EST
Call svcAddWorkObject
Explain Call svcAddWorkObject OOTB activity, how it works and parameters it take
Updated: 6 Mar 2023 6:55 EST
Bits In Glass
@AbhishekC1725 Hi Abhishek Please go through the link provided below, this will be helpful for you.
Updated: 1 Mar 2023 23:01 EST
Rulesstack Private Limited
Hi @AbhishekC1725,
svcAddWorkObject OOTB activity, Creates a work object we have to pass the flow name organization and the work page name
Please find the attached document for your better understanding
Abhishek Choubey Karunarathna Asela
@Mohd Qizer Uddin Thanks for this
Mohd Qizer Uddin
Bits In Glass
Mohammad Arman Khan
@I_amFrk05 Thanks for this post and information
Bits in Glass
@AbhishekC1725 svcAddWorkObject will create work object for you.. NewFromFlow and pxCreateTopCase will also create case for you.
1. If you want to just create case by passing the case type class and flow class, then use NewFromFlow.
2. If you want to create case and copy data from current case to new case and do some kind of data manupulation, you can use pxCreateTopCase. Activity will input Data transform rule as a parameter. You will also have a OOTB behaviour to store created case id to the current case property.
3. If you want to use create case and use advance features, use svcAddWorkObject , like passing Coverhandle as parameter(created case will be created as subcase), perform security validation(by passing returnNextActionInfo as true in with parameters) -> whether current user has next assignment to work for the newly created case. If yes,CurrentUserHasOwnership will be set as true in the background. If you want to skip create view for the newly created case you can pass SkipCreateView as true in with parameters. Note:- To check how this activity has to be used, you can use CreateWorkFromEmail for the reference. CreateWorkFromEmail uses svcAddWorkObject to create case in the backend.
But all these 3 activities basically in the background does the same-> Creates workPage and call AddWork to create a case in the background. Based on your additional requirements you can choose which activity to use.
Renuka Boddu Abhishek Choubey Nilesh Hedaoo Anoop Krishna Satya Sai Deep Kuna
@Anoop Krishna Thanks for the information
