Staidlogic LLC
Last activity: 22 Feb 2023 11:33 EST
GroupBy Field Clickable
Can we make GroupBy Field as Link(Clickable) on Table Layout in Pegav8.8 Theme-Cosmos ??
@NARASIMHAREDDYN Hi, If you are using the table layout, use the below configuration to enable the personalization options
Also enable the below item- Allow Group by
Please let us know if this helps
Staidlogic LLC
Hi @SrinidhiM
I have been enabled all these options and changed the Groupby Field as Link, but not able to make the Groupby Field result as Link on the table Groupby results.
Have you customized the ootb section which displays the group section? if so please check with the one which is OOTB and let us know if you see the same issue.
Staidlogic LLC
Hi @SrinidhiM
we ae not able to found the OOTB Section rule. While inspecting we found it is dynamically loading on the table. Please refer below image. we have to make highlighted one as clickable.
Updated: 21 Feb 2023 4:31 EST
@NARASIMHAREDDYN Hi, Are you seeing this column to be grouped by default on load? is that the issue you are trying to address, if yes then there might be few settings on the column level, Click the entire column and check the setting there. Also can you please provide the configurations of table layout so that i can try out the same at my end and figure out what is the issue. Also please check the below screenshot i have configured the table layout with group and i am able to click and group it and ungroup it. Please share the configuration
Staidlogic LLC
Hi @SrinidhiM, We are hiding groupby column on load of the table and trying to make the group by value as clickable.
@NARASIMHAREDDYN Can you please provide your table configuration, so that i can check from my side as well
Staidlogic LLC
Hi @SrinidhiM, please find the attached document of the table configuration.
@NARASIMHAREDDYN Hi I have checked the configuration, when you have configured the column as shown below it means that the column will be hidden at the load and user will have to enable it.
so either you have to change it to the second option or do as below:
click on fields and select the label checkbox (the which you are trying to make it clickable). Please let me know if this works
Staidlogic LLC
Hi @SrinidhiM,
we will not show the Group on the pytabletoolbar section for the table. So, we cannot enable the Label column. We have to make the grouping result value as clickable without showing the label column on the table.
@NARASIMHAREDDYN Hi if that is the case then can you select "Initially visible and user can able to hide it" on the column settings ?
Staidlogic LLC
Hi @SrinidhiM
our requirement was to make the grouping row value as clickable and we have to hide the Label column on the table on load.
@NARASIMHAREDDYN I believe that is not possible ootb because the column as such is hidden
