Virtusa Consulting and Services Pty Ltd
Last activity: 18 Jun 2024 13:58 EDT
Pega 8.5.1 to 8.8.1
getting the below error in update logs and update failing:
[java] 2023-02-07 14:08:14,833 ( SQLLoaderInternal) INFO - File: oracledate032.sql
[java] 2023-02-07 14:08:14,833 ( SQLLoaderInternal) INFO - ALTER TABLE PRPCDATA.PR_DATA
[java] 2023-02-07 14:08:15,493 ( SQLLoaderInternal) INFO - Failed to execute SQL in file oracledate032.sql
[java]
[java] java.sql.SQLException: ORA-02437: cannot validate (PRPCDATA.PR_DATA_PK) - primary key violated
[java]
[java] at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:509)
[java] at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:461)
[java] at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:1104)
[java] at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:553)
[java] at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:269)
[java] at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:655)
[java] at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:229)
[java] at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:41)
[java] at oracle.jdbc.driver.T4CStatement.executeForRows(T4CStatement.java:928)
[java] at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1205)
[java] at oracle.jdbc.driver.OracleStatement.executeInternal(OracleStatement.java:1823)
[java] at oracle.jdbc.driver.OracleStatement.execute(OracleStatement.java:1778)
[java] at oracle.jdbc.driver.OracleStatementWrapper.execute(OracleStatementWrapper.java:303)
[java] at com.pega.pegarules.install.SQLLoaderInternal.readAndExecuteSQLStatements(SQLLoaderInternal.java:160)
[java] at com.pega.pegarules.install.SQLLoaderInternal.load(SQLLoaderInternal.java:119)
[java] at com.pega.pegarules.install.SQLLoader.loadInner(SQLLoader.java:99)
[java] at com.pega.pegarules.install.SQLLoader.load(SQLLoader.java:78)
[java] at com.pega.pegarules.install.SQLLoader.main(SQLLoader.java:66)
[java] Caused by: Error : 2437, Position : 44, Sql = ALTER TABLE PRPCDATA.pr_data
[java] ADD CONSTRAINT "PR_DATA_PK" PRIMARY KEY
[java] (
[java] "PZINSKEY"
[java] ), OriginalSql = ALTER TABLE PRPCDATA.pr_data
[java] (
[java] "PZINSKEY"
[java] ), Error Msg = ORA-02437: cannot validate (PRPCDATA.PR_DATA_PK) - primary key violated
[java]
[java] at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:513)
[java] ... 17 more
[java] 2023-02-07 14:08:15,493 ( SQLLoaderInternal) WARNING - Statement: ALTER TABLE PRPCDATA.pr_data
[java] (
[java] "PZINSKEY"
[java] )
[java] ********************************************************************************
[java]
[java] Encountered a SQL Exception, clean schema before running again.
[java]
[java] Exception in thread "main" com.pega.pegarules.install.SQLLoaderException: Error executing SQL statements
[java] at com.pega.pegarules.install.SQLLoader.load(SQLLoader.java:81)
[java] Caused by: java.sql.SQLException: ORA-02437: cannot validate (PRPCDATA.PR_DATA_PK) - primary key violated
[java]
[java] ... 1 more
[java] (
[java] "PZINSKEY"
[java] (
[java] "PZINSKEY"
[java]
[java] ... 17 more
In-place upgrade on existing schema.
