FPAI
FPAI
FPAI
Posted: Dec 21, 2022
Last activity: Dec 23, 2022
Last activity: 23 Dec 2022 6:38 EST
Chart: Column Clustered counts issue
I'm using chart in section (chart type- column clustered) and data source is report definition. And on the Y-axis I'm using counts. when the actual counts for a bar is 39876 then it is showing as 39k and other bar which has count as 12 as 12.
When add decimals as 3, then 39.876k and bar as 12.000. Decimals auto is not working as well- getting 39.87k.
When I run the report definition stand alone I'm getting the exact numbers- 39876 and 12.. Is there a way can I get this dynamically (I need the entire number to be shown) without providing decimals?
***Edited by Moderator Marissa to add Capability tags***
