Pega Tealium Integration Component
Pega documentation site mentions that Pega Tealium Integration component is available at Pega marketplace and provides directions to use the same, however could not locate this component at Pega marketplace.
Kindly provide the link to access this component at Pega Marketplace.
@ArnabD75
This class should get auto-generated on save of the summary rule into the implementation rules ruleset. The save location is based on proper configuration of your context dictionary ruleset.
Can you please confirm that your context dictionary is set to the rules ruleset of your implementation application and is pointing to an open unlocked ruleset version. And that you have then opened the summary rule "FSAggsBehavioralEvents" and hit save on the summary rule.
