Managing emergency fix
In our client, they use same QA & STG envs to test both weekly maintenance code and ECR code (emergency change request; SEV1, same day fix & deployment). Since they both use same envs, this sometimes create conflicts in code - e.g. ECR testing sometimes contains weekly maintenance code, which is not deployed to PROD until later.
Client has been asking to create a separate application to test for ECR code only, but we couldn't quite figure it out when both weekly maintenance and ECR codes are using same envs.. Any insight is appreciated.
@Will Cho Create multiple application so that you can hold the ruleset version based on the application type if you are still going to use single environment, that will be the right option to use.
In the Application rule set the ruleset version to that patch version present so that new rules are not picked even if they are in database.
