LTIMindtree
SA
Last activity: 5 Nov 2024 5:20 EST
SSO-Login Issue - Invalid State Parameter error
We have configured Single Sign-On Authentication Service and it was working fine for sometime. Started facing an error while using SSO Authentication Service as "Invalid State Parameter Received".
Did not get any clue on why are we facing the issue. We have even tried re-configure the SSO Authentication Service again but the same problem occured.
@Kishore Sanagapalli
Follow-Solution for identified RCA:
As part of Application Security enhancements, CSRF Settings enabled in the application and 'Enable Same Site Cookie Attribute' which is selected with "Strict" is causing the issue. Updated the value from "Strict to Lax" which fixed the SSO Login Issue.
