KDDI
JP
Last activity: 20 Sep 2022 9:38 EDT
I want to close the Basic Authentication window of Internet Explorer with a Pega Robotics.
I want to close the basic authentication window using PegaRobotics' automatic process under Windows 10, but I can't do it.
In Windows Server environment, I could get the Cancel button by introgation and could close the window by pressing the button with robotics automation.
On the other hand, in Windows 10, the button cannot be obtained by introgation, but the window itself can be obtained. I tried to specify an escape key for the window by using send keys. As a result, the window could be closed in the unit test in Robot Studio, but not after deploying.
The environment used is as follows.
Environment that could be used: Windows Server 2012 R2 Standard, Pega Robotics 8.0
Environment that could not be used: Windows 10 Pro, Pega Robotics 19.1: Windows 10 Pro, Pega Robotics 19.1
We have also attached a screenshot of the basic authentication window not closing.
Can you please tell me the solution to this problem?
