Accenture
Accenture
Posted: Aug 15, 2022
Last activity: Aug 15, 2022
Last activity: 15 Aug 2022 9:58 EDT
Issue adding a widget to user dashboard
I am on the final mission exercise of the system architect course titled system architect.
On step 14 when I try to add a widget there are no widgets that appear or allow for me to select.
What would cause an issue in which there are no widgets available?
@JosephC16579254 Hi Joseph,
This issue is usually caused by security settings on a corporate network, VPN, or proxy server issue.
If you are on a VPN, try disconnecting from the VPN. If you are on a corporate network or proxy server, it could be the firewall/security settings - try attempting the challenge from a different network.
