Comman Wealth Bank or Australia
Last activity: 10 May 2022 8:14 EDT
Error: Stream service is not running in the cluster. - even after updating the java parameter as -DNodeType=Stream
Hello -
For Pega-8.7 - we are not able to see the stream service online, even after configuring the stream node's java params as " -DNodeType=Stream" and also in Decisioning: Services - stream nodes status is normal.
Please help us with a resolution ASAP.
@SusheelA1150 did you go through the troubleshooting suggestions listed in other forum posts?
https://collaborate.pega.com/question/error-stream-service-not-running-cluster
https://collaborate.pega.com/question/error-stream-service-not-running-cluster-0
https://collaborate.pega.com/question/stream-service-not-enabled-error-while-starting-pega-service
There is a checklist in this discussion:
Deploying and operating stream service
Other suggestions are listed in the Documentation:
Monitoring the Stream service
Status parameters of Stream nodes
Troubleshooting the Stream service
