Tech Mahindra
Last activity: 4 Jul 2022 8:08 EDT
Pega 8.6.1 upgrade issue
I am unable to sort the table post upgrade of pega 7.1 to 8.6.1.
***Edited by Moderator Marije - changed Support Case Exists to Support Case Created , added client Support Case Details ***
Likes (6)
Narasimha vulisetti Will Cho Nagendra Jaini Devjyoti Giri Vinay Avvaru and 1 More -
Updated: 19 Apr 2022 8:46 EDT
Tech Mahindra
@MarijeSchillernIt was an issue related to dynamic layout refresh action on focus event.
Issue got resolved.
@Nandhini.Mani please could you provide the following details:
- can you provide details of the table data source?
- can you provide screenshots illustrating the working and non-working behaviour?
I have found one example which is currently being looked at by our engineers. In another user scenario the sort order of CaseIDs in a Grid has changed following a patch update above 8.4.4.
Originally in earlier releases the Case ID (pyID) appears to be sorted numerically based on the number after the case prefix. e.g. T-1 T-2 T-10 T-11
After patch update to 8.4.4 the order is alphabetically e.g. T-1 T-10 T-11 T-2
The reason for the change in behavior seems to be the fix in 8.4.x onwards in the activity pzSortClipBoardData code using myComparator[0] = "";
vs myComparator[0] = "Lib(Pega-RULES:Sort).compareUnicode";
===> Is this the issue you are also encountering?
This issue has been found to be a product issue and logged under BUG-656552. (Sorting is not working properly in Grid/Table).
It is due to be fixed in 8.6.4 which is due out : April 22nd
If this is not your issue, please can you provide more details?
Updated: 8 Apr 2022 8:26 EDT
Tech Mahindra
Data source: Datapage
In table we have sorting present for createdatetime, when we click on sort
1. Ascending order is working fine (MM-DD-YYYY)
03/01/2022 09:55 AM
04/04/2022 05:21 AM
04/04/2022 05:22 AM
04/05/2022 09:33 AM
04/06/2022 05:09 PM
04/06/2022 05:11 PM
2. Descending order is not working (MM-DD-YYY)
04/06/2022 05:09 PM
04/05/2022 09:33 AM
04/06/2022 05:11 PM
04/04/2022 05:21 AM
04/04/2022 05:22 AM
03/01/2022 09:55 AM
@Nandhini.Mani if no other forum users provide any input I would suggest that you log that as a support incident.
If you go down that route, please can you provide the incident number here in the post so that we can help track it?
Tech Mahindra
@MarijeSchillern Thank you.
We created the INC for this.
@Nandhini.Mani Could you please provide the incident number here in the post so that we can help track it?
Tech Mahindra
@MarijeSchillern Please find the INC-219859
@Nandhini.ManiINC-219859 is not related to this issue, nor from the same company. Can you please check again which support ticket you have logged for this?
Tech Mahindra
Issue got resolved.
Accenture
MY
@MarijeSchillern is this issue resolved ?I mean pyID sorting issue.
