Get data of a new work object from an existing work object
I have a work object of the class A (A1) with a button that has the 'Create Work' action to create a case of the class B (B1). I need to retrieve the new ID of case B1 to set it in a property of the case A1. The problem is that when I do the set in the case A1, case B1 is not yet created (in other thread) and the field is empty. Any suggestion?
Attached image of the configuration.
