Hoverstate
SV
Last activity: 22 Mar 2022 12:26 EDT
Pega Extract - No Instance found in the database
Hi everyone.
I've been having some issues while trying to do an Extract of a specific Index- table.
I created the class Index-TestClass and records are being created through a Declare Index, there are instances there since I've validated it in Dev Studio, but whenever I try to run my extract rule (Created in the same Index-TestClass class), I get the error message "No Instance found in the database".
I tried using the Filter Criteria "Use last updated time as start", and I also tried adding only a really generic filter just to test (pxCreateDateTime is not null) but I got the same error in both tries.
In the BIX Logs I see the following messages whenever I try to run the extract:
Processing extract rule with insKey: *My extract Key*
bix/useHistoryClasses setting has been disabled
Unable to process Index-TestClass: null
# Total Instances Retrieved: 0
Has anyone ever experienced an issue like this one? Is it something from my side while configuring this that might've caused the issue?
Thanks in advance!
- Luis Orellana
