Centene Corporation
Last activity: 15 Jun 2022 8:52 EDT
DisplayAttachFile is running on click of link but popup does not appear
I am trying to use the DisplayAttachFile action on click of a hyperlink in a modal created during the click action a create MI button.
When the user clicks on the create button to create a new case, the system is searching by memberID and LOBState and filtering cases in the last 7 days to create a list of recent cases for the member to avoid duplication.
The RD that populates the list also displays the name of the initiating document and there is a hyper link next to document name to view the document. This is the hyperlink that has the run activity DisplayAttachFile.
I can see in the tracer that the DisplayAttachFile is running, but the popup that shows the download does not appear.
Does anyone have an explaination for this? When I run the activity from Dev Studio it gives identical tracer output but also displays the pop up I would expect.
Using Pega 8.5
***Edited by Moderator Marije to add Capabilities and Product and Version***
@RichardM3864
I've been facing similar issue here once upgraded to version 8.7 (from version 8.4), and realize that from version 8.4 to 8.7 the activity DisplayAttachFile changed under Security TAB, as per images below.
I'm not sure if this was already present in version 8.5 (the one that you are using), so it may worth check if it's not the same case for you.
Las
