![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689992000/6417a7af-32b6-4f95-b74f-dd7156f3a59d.jpg?itok=p_DK77aT)
Atos Consulting
Last activity: 24 Dec 2021 7:22 EST
Parameter in Report filter called from Data Page
We have a report definition that uses a parameter in its only filter. We have checked the box " use null if empty".
When we run the report without providing a parameter, it returns zero results. Which is expected, the filter blocks all records as the parameter is not filled in.
Now we have a datapage with the same (not mandatory) parameter, which is loaded by the report given above. We use "pass current parameter page". If we run the datapage without providing a parameter, the datapage is loaded with all records in the table. In other words: the filter is not working. This is an unexpected result.
We can think of a workaround, but we were wondering if somebody has experienced this before, and if this is a bug in Pega?
(Changing the "pass current parameter page" to passing the actual parameter does not change the situation sketched above)
