Pop Up Displays on Navigating away from a Screen
I have a Harness that calls a Section as below.
This section calls a GRID Repeat Layout as shown below.
This displays as follows to the user
The PPR is a drop down list and user can select a drop down value and click on the 'Update' Button to change the value. The Update Button calls an activity which updates the PPR value and then refreshes the screen, which shows the updated to the user.
After completing this operation, whenever I navigate from this screen by clicking on the TAB Menu, I get a pop up as shown below. This pop appears ONLY when I run an update and NOT otherwise.
Can some one kindly point out how and where the pop up up code is being set and how I can turn this pop up off.
