need to enable/disble agent using DSS
Hi ,
I want to enable/disable advanced agents using DSS.Can some one suggest how to achieve this.
Pramod.
  Hi ,
Pramod.
  With DSS, you can only do the following -
1. Add a new step at the beginning of Agent activity to check the value of DSS and exit the activity if certain criteria is met.
Your agent will still remain enabled, but skip the processing based on DSS value.
  Thanku @Nirmalya.SenSharma
