Cognizant
Last activity: 20 Oct 2021 12:21 EDT
Add additional node to the search index setting configuration
Hi Team,
PEGA platform version 7.4
I would like to know the steps to be aware of adding another node to the search index setting.
For example we already have a node enabled with search settings, now we want to include one more additional node in the search index.
As in the image, i already "host node id" added referring to this path /var/opt/pega/explicittempdir/abcd
now to add a second additional node - I would be using "Add node" option and mention the node id and create path "/var/opt/pega/explicittempdir/abcd" with the same permissions (or mount this location as NAS folder, so that the folder would be shared between the nodes) as the first mentioned node and include this path in the search setting and save the configuration.
Apart from these steps is there any "App Server configuration" that should be performed. or any nitty gritty stuff that should be paid attention to? Please let me know
Thanks & Regards
