Not able to add a node in search index
When I am trying to add the node in search index its not happening after sometime when am refreshing its going off can you please help me on this
***Edited by Moderator Marissa to update Content Type from Discussion to Question***
@sumank765 that sounds like a clustering issue or an issue with the indexer running on the new worker node you're adding. Are you certain the node you're adding is starting cleanly and clustering with the node you are logged into? If the cluster is fine and remains connected, does the indexer start, run for a while and stop? If so does the new node you're trying to add have a proper index file with plenty of disk space to index?
