Search index node - Add node button disabled
I am following the Exercise Guide of Senior System Architect and the very first thing it mentions to enable verify the indexing node.
I logged it as [email protected] (which has SysAdm4) permissions but 'add node" button is disabled and i can't add the node. The "All Work" option is also disabled.
The Pega log shows the following which i believe is due to incorrect node setup.
2017-04-29 19:53:27,169 [http-nio-9080-exec-8] [ STANDARD] [ ] [ PegaRULES:07.10] (Search.Data_Find_Search.Action) ERROR 192.168.0.22|192.168.0.10 [email protected] - Search request failed. Query: [*DMSample*], Index [RULE]. Possible cause: Master node is not reachable. 2017-04-29 19:53:29,996 [http-nio-9080-exec-6] [ STANDARD] [ ] [ PegaRULES:07.10] (Search.Data_Find_Search.Action) ERROR 192.168.0.22|192.168.0.10 [email protected] - Search request failed. Query: [*DMSample*], Index [RULE]. Possible cause: Master node is not reachable.
I didn't change anything in VM just imported into Virtual Box (latest version). What do I need to fix the indexing as I can't search any rule due to this issue.
Thanks for your replies.
