    T-Systems India
Last activity: 24 Jun 2021 9:56 EDT
Unable to install Pega 8.6 personal edition
OS : Windows 10 64 bit, Already installed missing dll
Data Load: [exec] The process cannot access the file because it is being used by another process. [exec] pg_ctl: could not start server [exec] Examine the log output. [exec] Result: 1 [echo] [echo] Waiting for Postgres to restart... Jun 22, 2021 11:53:38 AM org.postgresql.Driver connect SEVERE: Connection error: org.postgresql.util.PSQLException: Connection to localhost:5433 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections. at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:265)
Note that, I am installing 8.6 second time as first time i was able to install on C with lot of tries: however due to size issues on C: i deleted PRPC folders on C: and tried reinstalling on D: after restart, installing missing dll but no luck. somewhere something is missing..need expert help here as i tried changing port numbers etc.....
