Accord (Ex Employer)
Last activity: 21 May 2021 6:43 EDT
Rule resolution and 'Use Class based inheritance' check box
Can someone help me understand this scenario:
While processing 'TGB-Purchasing-Work-PurchaseRequest' case, System is resolving rule 'CreateRequest'.
Following are the instances found with matching purpose, after eliminating the rules that are not available and inapplicable to user's ruleset and versions, these are the rules remaining:
If 'Use class-based inheritance to arrive at the correct rule to execute?' Checkbox in the class definition of rule type 'Rule-HTML-Section' is not selected, Rule Instance D will not be eliminated. Also Class base tanking will not be performed.
Question 1: Is my understanding correct so far?
Question 2: Since Rule A is withdrawn, Rule A, B and C will be removed. Which rule will be chosen as base rule now, Rule D or Rule G?
Naga Priya K
