Cognizant Technology Solutions India Pvt Ltd
Last activity: 23 Feb 2022 14:49 EST
Pega Personal Edition 8.5 Server not starting
I recently downloaded and installed the Personal Edition 8.5. It ran fine for 2 weeks. But on the third week, I found that the login page is taking forever to load. So while going through the server startup command window, I found the content attached below.
Can someone help me resolving this issue.
Likes (5)
Devi Abeydeera Satya Swaroop Dev S V P K H Wilfred Sam Samuel Railon PERUGU VAMSI KRISHNA keerthi yachamaneni -
Updated: 23 Feb 2022 14:49 EST
Tech Mahindra
CO
I faced the same problem and fixed it by deleting all the folders and files inside C:\PRPCPersonalEdition\ tomcat\kafka-data.
I took the solution from this link https://collaborate.pega.com/question/unable-startup-pega-prpc-851-personal-edition
Hope this can help you
FR
Do you mind adding your PegaRULES log as well?
Tech Mahindra
hi Marc,
even i am getitng this error frequently say atleast once in 8 to 10 days time. server stuck with following error messages. i am forced to reinstall always
even tomcat is not starting after this page. PFA catlina logs
hi Marc,
Located App Server independent MBean security configuration: pegajdbc://1429759317:0/prresources.jar!//prmbeans.properties
2021-03-26 15:12:03,745 [StreamServer.Default] [ STANDARD] [ ] [ ] ( priv.management.MBeanSecurity) INFO - The following MBean security configuration has been applied:
2021-03-26 15:12:03,745 [StreamServer.Default] [ STANDARD] [ ] [ ] ( priv.management.MBeanSecurity) INFO - deny.RequestorManagement.Clipboard=true
2021-03-26 15:12:03,745 [StreamServer.Default] [ STANDARD] [ ] [ ] ( priv.management.MBeanSecurity) INFO - deny.RequestorManagement.RequestorDetails=true
2021-03-26 15:12:03,745 [StreamServer.Default] [ STANDARD] [ ] [ ] ( priv.management.MBeanSecurity) INFO - deny.DatabaseManagement.DatabaseConnectionDetails=true
2021-03-26 15:12:03,885 [StreamServer.Default] [ STANDARD] [ ] [ ] (riv.management.MBeanManagement) INFO - MBean Management (Web) initialized for DefaultDomain
2021-03-26 15:12:06,042 [StreamServer.Default] [ STANDARD] [ ] [ ] (rvice.operation.StartOperation) INFO - Starting service [StreamServer.Default]
2021-03-26 15:12:06,432 [StreamServer.Default] [ STANDARD] [ ] [ ] (l.access.RuleCandidateIterator) INFO - Single candidate rule resolution optimization is enabled
2021-03-26 15:12:07,229 [e-registry-heartbeat] [ STANDARD] [ ] [ ] (.tasks.TopologyChangedDetector) INFO - Services topology has changed. Current topology:
This node ==> StreamServer.Default 2674001239ece57d809ebdecd26b3067 Proprietary information hidden JOINING (new node) 8.5.1 b049cecf-fc41-477e-929a-4b440e1ef474
Carelon
@SubhadeepG3397 Hi Subhadeep
Even I'm facing the same issue
have u found any solution?? Kindly share it if it is so...
Updated: 22 Apr 2021 0:00 EDT
Capgemini
SE
@SubhadeepG3397 I also faced the same issue.I deleted the contents of temp folder and it worked
Tech Mahindra
CO
Pruthvi Raj Dara Sushanth Kommera Antony Lawrence R
