Corporation Service Company
Last activity: 28 Jan 2021 22:41 EST
Print PDF
I have a requirement to print PDF through a background job in the application. I am planning to set up a Job scheduler and invoke a activity. However this code only seems to connect to a printer but unable to print. any ideas?
java.net.Socket socket = null; java.net.InetAddress addr = null; java.net.InetSocketAddress socketAddress = null; java.io.BufferedReader reader= null; java.io.BufferedWriter writer= null; java.io.InputStream input = null; java.io.OutputStream output= null;
int port =9100; int timeout=5000; byte[] bodyBytes = null; //byte[] modifiedBodyBytes = null; //String bodyString = null;
try{
addr = java.net.InetAddress.getByName(hostName); socket = new java.net.Socket(addr, port); socket.setSoTimeout(timeout); bodyBytes = new com.pega.pegarules.pub.util.Base64Util().decodeToByteArray(pyStream); oLog.infoForced("TestPrinter bodyBytes length "+bodyBytes.length); // BodyString = new String(bodyBytes, "US-ASCII"); // modifiedBodyBytes= BodyString.getBytes("US-ASCII");
try{
output = socket.getOutputStream(); oLog.infoForced("TestPrinter output stream "+output); input = socket.getInputStream(); oLog.infoForced("TestPrinter input stream "+input); // kick it out output.write(bodyBytes); output.flush(); oLog.infoForced("TestPrinter output stream "+output); socket.shutdownOutput(); reader = new java.io.BufferedReader(new java.io.InputStreamReader(input)); oLog.infoForced("TestPrinter read input stream "+reader); printerResponse = reader.readLine(); oLog.infoForced("TestPrinter printer response "+printerResponse); status = "success"; } catch (Exception e) { e.printStackTrace(); //oLog.error("TestPrinter Error in sending to printer "); oLog.error("TestPrinter"+e);
status = "fail"; } finally { if (input != null) try { input.close();oLog.infoForced("TestPrinter closed input stream ");} catch (Exception e) {oLog.infoForced("TestPrinter Issue closing input stream "); } if (socket != null) try { socket.close(); oLog.infoForced("TestPrinter closed socket connection ");} catch (Exception e) {oLog.infoForced("TestPrinter Issue closing socket "); } if (output != null) try { output.close(); oLog.infoForced("TestPrinter closed output stream ");} catch (Exception e) {oLog.infoForced("TestPrinter Issue closing output stream ");} }
