TSYS
Last activity: 7 Dec 2020 18:34 EST
Need to embed Nodejs code in section.
I am having a requirements to enable to scripts (which will subscribe some events ) when we click on the button in the section.
I am added some scripts in a section under Cpm-Portal class and added that section in TOP right corner near to the Phone icon.
<script>
var events = require('events'); var eventEmitter = new events.EventEmitter(); // listener #1 var listner1 = function listner1() { console.log('listner1 executed.'); } // listener #2 var listner2 = function listner2() { console.log('listner2 executed.'); } // Bind the connection event with the listner1 function eventEmitter.addListener('connection', listner1); // Bind the connection event with the listner2 function eventEmitter.on('connection', listner2); var eventListeners = require('events').EventEmitter.listenerCount (eventEmitter,'connection'); console.log(eventListeners + " Listner(s) listening to connection event"); // Fire the connection event eventEmitter.emit('connection'); // Remove the binding of listner1 function eventEmitter.removeListener('connection', listner1); console.log("Listner1 will not listen now."); // Fire the connection event eventEmitter.emit('connection'); eventListeners = require('events').EventEmitter.listenerCount(eventEmitter,'connection'); console.log(eventListeners + " Listner(s) listening to connection event"); console.log("Program Ended.");
</script>
This script is not get called at the
