Last activity: 2 Nov 2020 12:46 EST
Retrieve parameters passed in mashup
I have seen questions on how to retrieve parameter values passed via mashup and I am facing an issue where I can see the parameter value but am not able to set it to the workpage.
My mashup code is
<html> <body> <!-- ********************** Begin Pega content ********************** --> <script src ='http://localhost:8080/prweb/PRServlet/app/CRMFS1_7089/?pyActivity=pzIncludeMashupScripts'></script> <div data-pega-gadgetname ='PegaGadget' data-pega-action ='createNewWork' data-pega-action-param-classname ='UPlus-CRMFS1-Work-MSRInteraction' data-pega-action-param-flowname ='pyStartCase' data-pega-action-param-model ='pyDefault' data-pega-isdeferloaded ='false' data-pega-applicationname ='CRMFS1' data-pega-threadname ='LostOrStolen' data-pega-systemid ='pega' data-pega-resizetype ='stretch' data-pega-url ='http://localhost:8080/prweb/PRServlet/app/CRMFS1_7089/' data-pega-action-param-parameters ='{"MemberGuid":"abc","pzSkinName":"CRMFS1","pyMashupSkeletonName":"pyDefaultMashupSkeleton"}' data-pega-redirectguests ='true' ></div>
<!-- ********************** End Pega content ********************** --> </body>
My mashup code is
On the pega flow, in the pyDefault of the case, I am doing a set of .MemberGuid to Param.MemberGuid. In the assignment, I have a section where I am showing .MemberGuid as well as Param.MemberGuid. What I am seeing is that the Param.MemberGuid values show but the .MemberGuid does not. How have other been able to use the parameters that Have been passed from Mashup
