Cognizant
Last activity: 31 Oct 2020 21:14 EDT
Agent Schedule feature for job scheduler
For Agents ,we were able to do changes in the agent scheduler in higher env .For example if we wanted to to change the time when the agent should run we did not need a deployment and used to do the change in the agent schedule data instance. For Job scheduler i see we do not have the option.Is there any way around ? or pega have removed this option based on some thought .
Hi, We had a similar issue when agents are converted to the job scheduler. Now we are keeping the job scheduler in the production ruleset version to make changes in the higher environments.
