Dynamically set prconfig.xml - unique values per instance - Stream Service
Looking to learn how to have unique prconfig.xml values per an instance without having to create several ear files at a time.
We have been using DSS to set the values but have seen if our apps are on the same server we get binding issues. So DSS is not a solution since that shares the values across instances and we get failed to bind.
If possible I would like one ear file we can set the values of the prconfig.xml from the application server.
Maybe set the values through JNDI ? Not sure how feasible this approach is.
prconfig.xml
<env name="dsm/services/stream/pyport" value="java:comp/env/pyport"/> <env name="dsm/services/stream/pykeeperport" value="java:comp/env/pykeeperport"/> <env name="dsm/services/stream/pybrokerport" value="java:comp/env/pybrokerport"/> <env name="dsm/services/stream/pyjmxport" value="java:comp/env/pyjmxport"/>
We are on JBoss and I have seen that we set some values for datasource in the standalone-full-ha.xml
<subsystem xmlns="urn:jboss:domain:naming:2.0">
<bindings>
<simple name="java:/prconfig/database/databases/PegaRULES/defaultSchema" value="example"/>
<simple name="java:/prconfig/database/databases/PegaDATA/defaultSchema" value="example"/>
prconfig.xml
<bindings>
<simple name="java:/prconfig/database/databases/PegaRULES/dataSourceAdmin" value="java:/jdbc/AdminPegaRULES"/>
<simple name="java:/prconfig/database/databases/PegaDATA/dataSourceAdmin" value="java:/jdbc/AdminPegaRULES"/>
<simple name="java:/url/pega/none" value="file:/nul"/>
</bindings>
I am new to these concepts so not sure exactly what this configuration is accomplishing but it looks like it is creating a recognized JNDI with the prefix java:/prconfig/ to set some values there. Could we do the same to set Stream Service Ports?
Thanks for any guidance,
-Ben
