infosys
Last activity: 13 Oct 2020 2:00 EDT
Add Assertion on any step: Scenario Based Testing
Can someone explain in details about assertion and below features whenever we edit any step within a test case on portal or from DEV studio
1. Select Complete Task (Menu) : It has captured values ; what will happen if we edit and change this
2.Expected results
UI attributes: we have tooltip, value, label and other dropdown values ; role of each dropdown value
3.Actions
4.Advanced; what is custom selector?
Q> What will be the difference if we change the default value(UI attribute) and how it will impact if we go and add assertion and pick any random value as per the selected field from the dropdown.For e.g. if dropdown label while recording is "TEST". a)What will happen if we make changes to default value as "TEST2"?
b) what will happen if we add an assertion and select label and change the value to "TEST2" whereas "TEST" is also there as default value
On a similar note can someone explain for other values considering above question
Prajapati
