Bank of Nova Scotia
Last activity: 9 Oct 2020 7:06 EDT
Azure Repository - use of KeyVault and Private Endpoint Connections
I am working on a PoC to integrate Pega with an Azure Storage Account as a Repository. Based on default settings in Azure, I am able to integrate with my Azure Storage Account, and used a Blob Storage container. However, I understand these default settings in Azure may not meet security requirements of the bank. I am looking for assistance for the following two questions:
1. When I connected to my Azure Storage Account, I used the access key of the storage account. I copied the key from the Azure Portal and pasted that into an Authentication Profile for Azure. Can this key be stored in a Azure Key Vault, and reference that from the Authentication Profile? What will be the procedure for this?
2. I have set the Firewalls and Virtual Networks screen in the Azure Portal to allow access from All Networks. Is there any instruction in the Pega side set up so that I can use Private Endpoint Connections?
