Connecting Oracle in Azure through Azure Entra
We have to move our application to Azure cloud. Keeping latency in mind we are shifting our DB to Oracle in Azure. Both are in same Azure offerings (UBS and Microsoft managed). The problem is - the only way Pega can connect to this new Azure Oracle is through OAuth (where Azure Active Directory or Entra is used as the ID provider). They are not giving any other options. We use Pega 23.0.
The support we are looking from Pega
- Does Pega allow to connect Oracle using OAuth
- Considering 1 hr is the lifespan of an active token how can we assure stability in a PROD environment.
- During a container/POD creation, how can we get the token and establish DB connection.
@SayakB
Pega currently connects to Oracle using standard JDBC with database user/password or network-level security, not OAuth tokens from Azure Entra, so direct DB authentication via OAuth is not supported out of the box. In this setup, OAuth/Entra is normally used for app-level access (users, services), while the DB still uses a technical account managed by the DB team. For production stability, you should avoid tying DB connectivity to a short-lived 1-hour token and instead use managed identities / key vault + DB credentials, so your Pega pods always have a valid way to connect. Token-based flows are better used between Pega and REST/HTTP services, not for core DB connectivity. At container or pod startup, Pega just needs the JDBC URL and credentials; token retrieval and rotation should stay outside Pega (for example, handled by Azure infrastructure and injected via secrets). A common approach is: Azure Entra secures access to Key Vault, Key Vault stores DB password, and Kubernetes injects it as a secret to Pega, keeping latency low while still being secure. In short, use OAuth/Entra around the infrastructure and secrets, but keep the DB connection itself as a regular JDBC connection supported by Pega.
