JPMC
Last activity: 5 Aug 2020 11:40 EDT
how to handle Nested JSON which is coming as response from Connect-Rest
I am using a connect Rest service with Get method where Map to is JSON and Map key is .response page and below is the format for successful and failure response
The failure response is coming in the right format and I am able to see two fields under response page like response.errorcode, response.errordescription but issues is with the success response
The expected response is : response.HouseID but since it looks like a nested JSON the value is not captured on the page.The page looks empty,it is just having pxobjclass How to capture it?
But when I tried clipboard and used parameter as key type then i am able to see the parameter value as
param.response: {"HouseID": {"HouseID": "123456"}} but how can i use the value
For Success Response : {"HouseID": {"HouseID": "123456"}}
For Failure Response:
"errorCode":"103"
"errorDescription":"Missing required field XXX in the request"}
