Autocomplete Altering Text into Date?
I'm experiencing an issue where an autocomplete populated by a clipboard page is transforming text values into dates without the assistance of a data transform or activity. The autocomplete takes a text field containing up to 5 numbers and translates them to a date roughly corresponding to those 5 numbers. An example being 123, which when the autocomplete populates 123 it changes it to 12/3/2020.
Original field and recipient field are both text. The properties are text. The HTML control is text. It tries to do this for integer to integer but fails to populate because a date is not an integer and cannot be populated as such.
Any idea what could be causing this or what I can do to fix this?
