Last activity: 16 Jul 2020 3:40 EDT
Two Radio Buttons showing up instead of one in Pega 8.4.1
We are using Pega 8.4.1 and we see that two Radio Buttons showing up instead of one.
Following steps were tried:
1) Added a Dynamic Layout and added radio buttons inside Dynamic Layout'
2) Tried using customized CSS as a stylesheet in harness.
3) Made changes in Application Skin
All of the above methods were tried but to no avail. Please give suggestions to fix this issue ?
Updated: 15 Jul 2020 2:56 EDT
Is that cell with the radio button / table marked as "Read-only" ? if yes, make the cell editable and check if the radio button appears.
Hello Pritam,
The issue can be resolved with one of the following approach:
Approach One:
Navigate to Application Skin--> Radio Buttons--> Standard Control--> Uncheck "Use browsers default radio buttons"
Approach Two:
Navigate to Application Skin--> Radio Buttons--> override standard control and check the runtime.
Let me know if it helps.
Hi Rakshith,
I tried Approach One. It didn't work. For Approach Two, we are already using Overriding Standard Control. However we tried reverted it back to inherited and override again. The runtime was normal.
Thank you,
Pritam
Hi Rakshith,
I am seeing another type of issue in Radio Button. This Radio Button is sourced with a Boolean Property and has been used in a Table inside a section. On runtime the radio button is not visible and on selecting it appears like a Big Black Box.
Pritam
PFA screenshot taken from other Env.. The ideal way it should look like.
Hi Krithiga,
Yes, yesterday we already tried the above solution and it worked. Requesting you to tell me how making the radio button editable made it worked.
Thank you,
Pritam
When a cell containing is marked readOnly, it only shows the value in text format. Since no value was set on initial load, it shows up as "empty".
Actually the cell was initially marked as Auto and this works fine in other Env. which is in Pega 7.4.0 version.
I think the big black box, is more to do with Google update on improved accessibility
https://blog.chromium.org/2020/03/updates-to-form-controls-and-focus.html
Just wondering, could that be causing issues with the radio buttons as well. Try different browser and verify
Bala Sai Subrahmanyam
Hi Aneesha,
It didn't work with Cross-Browser verification. The issue still remains.
Thank you,
Pritam
