CBA
Last activity: 14 Jul 2020 21:28 EDT
Setting up a reports database in 8.4
Hi Folks,
Updated the Database Table data instances to identify alternate databases in the Reports Database field.
I am not able to find the Use alternate database checkbox on the Data Access tab of the report definition rules. PFA.
Updated: 14 Jul 2020 21:28 EDT
Maantic Inc
In Pega 8, RD data Access tab UI look is different. Reporting database dropdown does the same job as pega 7 checkbox use alternate database.
Updated: 14 Jun 2021 7:38 EDT
Lloyds Technology Centre
When you select the Reporting Database dropdown value as Prefer reporting data source if defined option, then the pyUseAlternateDB flag will be set to true, which meets your requirement.
CBA
I didn't get your reply, could you please let me know what I need to do in simple.
In the above reply, I was pointing to select "Prefer reporting data source if defined" value from the Reporting database dropdown in the Data access tab.
Please find the below screenshot added by John for more details.
Maantic Inc
Hi Sam, Did you check data access tab - reporting database dropdown. It has options primary data source only and Prefer reporting data source if it is defined
CBA
Hi John,
I have seen that, my question was regarding pyUseAlternateDB - this will get set or a check will display like in PEGA 7, PFA
Maantic Inc
CBA
Yeah, I got clarified thanks John.
