TCS
Last activity: 11 Apr 2016 16:10 EDT
Report Database
For reports its recommended to use Report Database (Note: Configuration done in Database Rule) which maintains the copy of the Work object Database instances instead of the Work object Database Instance directly.
Will the Report Database be appended with the instances whenever the new entires come into the Work object Database instance?
Is the Report Database a View (SQL Related)?
