Remove the Duplicates from the Pagelist using Data Transform.
I've a requirement to remove the duplicates from one Pagelist and copy the unique items to another Pagelist using Data Transform.
Tried using pyRemoveDuplicatesFromPageList, but no luck.
Syntax used in DT is,
NewAccountsList = @Utilities.pyRemoveDuplicatesFromPageList(pyWorkPage,".OldAccountsList","AccountNumber")
pyWorkPage: Jaguar-Triumph-Work-Bank
My Old Pagelist is .OldAccountsList and it has a column AccountNumber.
OldAccountsList(1).AccountNumber = 111
OldAccountsList(2).AccountNumber = 222
OldAccountsList(3).AccountNumber = 333
OldAccountsList(4).AccountNumber = 111
OldAccountsList(5).AccountNumber = 222
After running the Data Transform, Expected Result should be,
NewAccountsList(1).AccountNumber = 111
NewAccountsList(2).AccountNumber = 222
NewAccountsList(3).AccountNumber = 333
But while saving the Data Transform, its showing an error.Attaching the Pic of it. Could anyone give some idea please..!!
