Harley-Davidson Financial Services
Last activity: 22 Jul 2020 16:49 EDT
Exposing a Stream Data Set
I'm exploring processing events that originate outside of pega (external systems of record). It seems the Stream Data set with a data flow that utilizises various decision strategies would be the way for me to accomplish this. I can create the Stream Data Set and the "integration" section lists REST and WebSocket endpoints. However, there are a couple of problems:
- The endpoint is not accessible. The IP provided does not seem to exist. My instance is in the Pega Cloud, so perhaps this endpoint feature is only appropriate for on-prem Pega deployments?
- The endpoint is not over TLS, so even if I could access it, it would not be secure and I would not be able to use it.
- The Stream data set documentation talks about an "optional" set in creating a Connect REST rule so you can populate it with external data (which is my use case), but that seems backwards. Shouldn't I need to create a Service REST rule?
- Using a Service REST rule seems like the "right" way to expose the service so i could have all the regular Service REST endpoint configurations and features. If this is the correct path, how would I configure it?
John
***Edited by Moderator Kayla to update Platform Capability tags****
