Custom Stream Processing in Data Sets
I found the following on PDN, but the examples are too vague for me to follow. Our requirement is to read ZIP compressed text files that are encoded in a non-unicode format. Pega will unzip for us, but we have to do the string conversion in Custom Java classes
1/ In the input stream processing example they are using INT. Should I use STRING for mine, since that is what I am processing.
This page from 8.2 help shows the data-set rule filled in with custom stream classes:
Which are implemented:
Can anybody help with a better example
