TSPi
Last activity: 4 Mar 2022 15:24 EST
Personal Edition 8.4 - Cant open rules
Hello team, got the PE8.4. Able to login with Adminstator user, however not able to open any rules. Getting a blank screen on the right frame. No errors in the log apart from the below:
2020-06-22 00:19:15,819 [http-nio-8181-exec-4] [ STANDARD] [ ] [ PegaRULES:8] (rnal.rules.AssemblerHelperImpl) INFO localhost| Proprietary information hidden [email protected] - ruleMessageName = (Rule-HTML-Section)pxFieldValueMaxLength not found
Likes (3)
Dharanitharan Ravindran purama gopi Tom Yunus -
FR
How about if you try to create a new application with a new admin like user?
TSPi
Hello Marc,
No good luck. I have tried clearing the temp folder contents followed by restart. Still getting blank screen.
I am not able to create a new admin user too due to this blank screen in the right frame.
Charles Schwab & Co., Inc.
@MarcLasserre_GCS Any root cause for this? We are seeing this error in version 8.4.4. This is causing slow load time for rule forms on occasion for developers.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2023-07/f7f35052-5e7d-4ed9-ada9-87594f1d3c63.png?itok=bz3Ms_gZ)
Hi @JonConnolly,
Thank you for posting your question on the Pega Collaboration Center,
This appears to be an inactive thread and I would like to suggest that you ask a new question.
This will alert our SMEs of your new question and you should hopefully receive a reply soon.
You may include the original thread as a reference in your new question.
Thank you!
TSPi
Hello Marc & team, tried playing around switching applications, and creating rules / workobjects.
Finally, after a successful WO created and shown in the right frame,now able to open all type of rules.
Can you pls let know on the root cause if known ??
Updated: 14 Jun 2021 7:38 EDT
Did you restart the Personal edition and then it started working again?
Updated: 8 Oct 2020 6:00 EDT
Energy Safe Australia
We are also facing same issue in 8.4.1. Any solutions ?
Accenture
@DharanitharanR5430 - We are in Pega 8.4.1 and are getting this error on our logs when our portal freezes.... are there any actual solutions outthere - have you heard from someone after this post? I tried searching for these rules in Pega and they don't seem to exist... which makes me think this is an actual Pega Bug?
TATA CONSULTANCY SERVICES
@Sathish Kumar Hello Sathish . I am facing a similar problem but I am just not able to open any NEW rule forms or new rule forms using 'Save As' from anything existing. I am able to open all rule forms of existing rules. But not any new rule form. I tried clearing the temp directory and restarted the app JVM/server, still no luck. Any tricks or solutions for me to try and check ? Pls and thanks.
